Frame, axles, springs, hangers, H1's
thatK30guy
1 ton status
Here's what I have:
'74 K5 bare frame, every nut and bolt, line, etc., has been removed.
'87 DRW D60 and D70HD with 4.10's, complete hubs to hubs.
52" rear springs from the '74 K5 frame and 64" rear springs from a mid 90's 1/2 ton Z71 that has 3 leafs + overload.
DIY4x rear spring hangers (not shackle flips) to move the springs inboard to fit the narrower spring perch on the true 1 ton rear ends. You will need to finish this set up with the shackle flip brand of your choice as long as you get the 1 ton flip kit.
H1 wheels, 12 bolt, stock unmodified, no run flats.
Basically a project for anyone who is looking for this stuff and its all here. Just needs to be put together to your specs. Best thing about this '74 frame is that it has the crossmember readily accepting a simple regular cab bolt on affair. No mods or customizing a new crossmember, this one is stock and has holes in the correct locations.
$1250 for everything listed above. Priced low to sell quick! Pics to come later upon request. I'm in central Kansas 67439 zip and will help you load up onto your trailer.
And tires. And shocks. And whatever floats your boat. :D
