87BrnRsd
I havent been on this site for a while because I havent been driving my truck in the last 4 years. However, I am working on getting it running again and am having a slight problem.
The frame seems bent at the steering box. The truck has about 5.5" of lift with a 4" drop steering arm. When I was driving the truck daily for 2 years (2004-2006)the truck had no problems with steering. Then I locked the front (see my sig) and started wheeling it harder. I noticed that it got harder and harder for the power steering pump to turn the tires. The last trip it made, my brother was driving to recover a stuck vehicle. He got bound up in a bad spot which caused the ears to bend and break on one of the stub shafts up front. Ever since this, the truck will not turn right.
You can turn it left all the way to lock, but when the wheels hit center you cannot physically turn the wheel to the right. Also after this the front bumper noticeably was bent down towards the drivers side. We suspected it was bent at the steering box. It appeared to be kinked down a lot more than the passenger side. We inspected for cracks but there are none. We used a winch and and anchor and got the frame bent up some. It will now turn about 1/3-1/2 to full lock to the right. When you turn the wheel to the right and the tires stop, it appears to be that the angle of the pitman arm and draglink are binding up and causing it not to turn right.
My question is how to fix this? I have the weld on ORD frame brace but I need to get it steering correctly before I put this on. Any suggestions? It looks like a larger drop steering arm could fix the steering issue. Then I would brace it with the ORD brace and hope it never moves again. But this almost seems like the band-aid idea and I really need to fix the real issue.
Anyways, me and my brother have been working on this problem for a week now and I need to get it fixed soon. Any suggestions here? We are running out of ideas.
Thanks,
Harrison
Thanks,
Harrison
