There are a couple more differences to consider. 1) The rear cab mount surface is higher on a '81up truck. This can be remedied by either spacing the newer mounts on an older frame, or by using the '80 and older mounts. 2) On 81up trucks, the hole for the body mount is bigger. You can hog the older frame out to accept the newer mount, but it is not fun. Voice of experience.
Easiest thing to do if you are going to put a '81up body on a '80 and older frame would be to use the '80 and older mounts.
Someone please correct me if I forgot something.
