I thought the spacers were there to accomodate the lift?
I'm glad to know this. I've found a few other cheap fixes with this thing too. So is there a kit or what is the "correct" way to fix my problem with the spacers? Should I get rid of them completely or put them back in the stock location? I want to do everything the right way the first time.
I've actually seen those spacers on top inside the frame also. Guess it makes no difference
Ok stupid question of the day. I'm not a welder by no means so bare with me
Why do you drill the hole in the end of the crack?? Does this help it to not crack later??
That is a classic example of how not to correct for bad driveline angles.. IMHO even using a spacer to space the case down is borderline retarded, but at least it won't crack the frame like that abomination did.
When you space the case down, it worsens your front drive shaft angle since the t-case mount rotates down on the motor mounts, the front out put ends up pointing upwards. You really can't afford that in these trucks, and fixing the front angle is harder than the rear, if you are concerned about your caster..
Best solution, put the crossmember back to stock, fix your pinion angle and get a proper shaft made.
Here's a pic showing how those spacers are supposed to be used, at least in regards to both my rigs(the 89 with a 700r4/241 and the 91 with a 4l80e/241). I would think for the NP208 it would be the same or similar. My 91 has a 4" lift on it, but with a Suburban I've got wheel base on my side
Sorry for the sh!t quality, but it gets the job done![]()
By the way since no one mentionned it I figured I might as well:
Those tubular spacers come stock on a couple of places in our trucks, they have them here at the crossmember and at the steering box.
It's to give a longer bolt a chance to work in tention.
The longer the bolt, the better clamping without stretching the bolt beyond it's elasticity, and since both locations are across less than 1/4" thickness, they add 1" or more of length to the bolt with these spacers.
I did eliminate them on my truck and after running less than a year my bolts loosened up.
About time somebody told us why those spacers are on our trucks. The spacers are there for a reason and if GM could save a few cents by not putting the spacers on, they would have.
I wonder why GM put the spacers for the cross member on the later blazers? I don't think there is much stress by the cross member as compare the steering box.
I think the later blazers have thinner frames than the early blazers.
I need to check this out.
Edit--the early model blazer have the cross member mounted on the top and bottom of the frame rails. Therefore, more mounting points and more load carrying capacity.
Edit--Opps wrong thread and about something else.As I said, I tried with my blazer to eliminate those spacers, and within a few months, I lost a couple of the bolts, and finally I ended up on a trail with a tranny tcase on the ground. Good thing I carried spare bolts and nuts.
It didn't help I had a big 5.9 l Turbo diesel vibrating the bolts lose, but still the clamping force of a stretched bolt can only be replaced by a good thread locking compound or safety wire, and I didn't want to do either.
By the way, not all the trucks came with the double cross memeber, some just got the same as the newer one, just one layer, I am guessing it was more for the 203 equiped trucks, dunno...
Santa Maria... what is there I can see there, I will be there on Tuesday waiting for a load to be loaded, is there anything interesting I can do for a couple of hours?
