The tear down got back into gear today. Removed Roof, quarter panels and bed. Went well but found some issues to discuss.
1. FRAME DEGRADATION - Found the lower part of the frame steel (part that faces the ground) had heavy rust flakes. Brushed the rust off and found the lower frame along the bed area was thinning considerably.
--Should I media blast these areas and just POR15 it or should I media blast and weld in some new steel in this area. Was. Thinking of laying the new steel along the bottom face rather than the inside face.
2. BODY MOUNT DEGRADATION - Found the 2nd to last body mount brackets are shot. See photos.
-- Replace or repair? I'd replace if I had any chance of finding these mounts
3. SHOCK MOUNT WELD - Found a previous owner welded in a steel plate on the top of the frame where the mount is... Not sure why this was done. ALSO, the top mount hole appears to have a weld repair. I need to remove this shock to see more but does anyone have any ideas what's going on here.
--Is there a solution that one of the suspension fab companies sell to improve this design or fix any issues that seem to be present?
Any help is always appreciated.
