'72s never had a big block in 4wd from the factory. They won't fit in the factory engine crossmember location. It took some research and work to make mine clear without the common sledgehammer massage that I saw more than once.Shoot a big block was designed to fit a squarebody, my 8.1 doesn't touch the firewall there. Looks like the firewall damage is from a hack that installed the last engine. Must have swung it in with some force and bounced it off the firewall a couple of times.
There I go assuming it was a square. Duh.'72s never had a big block in 4wd from the factory. They won't fit in the factory engine crossmember location. It took some research and work to make mine clear without the common sledgehammer massage that I saw more than once.
Hello again,
Any idea why these would be like this? Maybe headers at some point. Maybe a big block install. Hell I don’t know. Strange.
