Any of you guys reinforce your frame where the front spring shackle mount is..? Im thinking of plating the frame with 1/4 inch plate on the outside of the frame rail and using diy4x washers to space the shackle out so the bolt heads of the mount dont hit the shackle. I cant plate the inside since it would push the shackle too far and interupt my header collector. Any ideas on this...?
I have new fush mounts with poly bushings, grade 8 bolts and some 3/8 thick shackles. I just want it to be sturdy and not bend the frame when flexing. The truck was in an accident many years ago and the rail is a little tweaked(5 degrees)....
