scottystills
Well looking at some frame strengthening options. Tis the season for contemplating winter projects...
We're all aware how much these frame tend to flex, and I'd like to minimize it as much as possible. Starting to think my winter project might include a power plant upgrade so would likely be a necessity to make sure the frame will handle it. Alternatively would moving to a link/coil front susp take some of the stress off the frame that the leaf springs seem to cause?
The way I see it I have 3 options:
1. Plate/box the existing frame. Pros: easier to source, probably cheaper in the long run. Cons: Seems like a lot of work to work around the existing frame attachments, not sure how much strength it will net compared to other options. Difficulty 2/5
2. Source and modify K30 boxed frame. Pros: Easy to source, fully boxed frame, should be straightforward to move existing suspension from one to the other. Cons: Frame needs to be shortened but I luckily have a buddy who is a welder/fabricator who should be able to manage the job very well. Body mounts need to be moved I'm sure but should be easy enough. Difficulty 3.5/5
3. Build new frame. I blame some of our members for putting this idea in my head as I follow their frame build threads.
Pros: All new material, easy to customize during build. Cons: Time consuming and difficult to do properly, very likely the most expensive option. Difficulty 5.5
Tossed up, but probably the first step of the next iteration of my truck. Definitely don't want to go way down powerplant and suspension upgrades just to find the frame isn't up to the job.
Thoughts?
Pros: All new material, easy to customize during build. Cons: Time consuming and difficult to do properly, very likely the most expensive option. Difficulty 5.5Tossed up, but probably the first step of the next iteration of my truck. Definitely don't want to go way down powerplant and suspension upgrades just to find the frame isn't up to the job.
Thoughts?
