notsosanestan
Registered Member
okay so i cannot seem to pin point this popping feeling i am getting through the steering wheel. Its usually only when i make a left turn then turn it back. But also when i hit a bump i can feel something moving around. Also when i was looking for a loose steering box or cracked frame i can see the frame flexing when i go lock to lock. Is this normal? and suggestions? Everything on the front end and axle is tight. Truck has a 4 inch lift ord crossover steering, heavy duty from shackles,FUSH kit,steering box plate, and steering box brace kit.
