OK, here is the deal. My cousin, Baitfish2 has a '91 1500 2wd. I have saved that truck about 4 times.
He will get a new truck, and want to sell or just junk 'Ol Blue. I will talk him out of it, and pretty soon, it saves the day.
Son came home on leave from Iraq, needed something to drive, crank up 'Ol Blue.
Daughter's car craps out, she drove 'Ol Blue for a couple of weeks.
Wife's medication causes her to pass out and roll his main truck about 3 times, ( She was pretty much embedded in the cab, took them 30 minutes to get her out, only some bruises and a scratched arm) 'Ol Blue got him back and forth to work until the insurance replaced his truck.
Finally, when his regular truck was having problems about 2 years ago, he was headed into work in, you guessed it, 'Ol Blue.
The tank on one side of the rad split, and he did not notice anything wrong until the knocking noise over rode the radio.
I got one of my wrecker guys to go get the truck. The 350 got so hot that the plastic center of the temp sender melted.
We changed the oil, tried cranking it with no water. It fired right up, ran good.
So, we put a rad on it, and it went back to work. He swore that it had more power than before.
I think someone here suggested that it had annealed the rings and made them have less friction.
Then, the transmission started acting up, finally lost a gear. He decided that it had gotten too hot also.
The entire steering system except for the gear box had just been replaced, and everything else was working pretty good.
He decided to try rebuilding the tranny himself with my help.
We dropped the tranny, used my boom truck to pull the engine. Put it on a stand, pulled the heads.
Engine looked excellent. He took the heads down to get them rebuilt, and all was on track for a rebuild.
Then, like so many of his ideas, it just died.
He sold the heads, the transmission is still sitting in my wheelbarrow in the shed.
He needed some door parts for his newer truck, came over and stripped out the passenger side door.
Yesterday, he showed up, we pulled Blue out of the field, and started stripping it.
It goes to the crusher Wed. or Thurs. He has everything off it he wants, and wants to leave anything with any weight to speak of on it.
But, I see trim parts, side mirrors, all kinds of stuff that other folks might want.
So, I took some pics, and here they are.
Bearing in mind that I am slightly limited by my leg, and have been having some kind of an issue with my right hand for the past week or so,
if anybody sees something worth the shipping, let me know and I will try to save it.
The heavy stuff, like the axle, he wants to leave for weight. But if I pull something off and he gripes, so what.
The radio was an aftermarket Blaupluket, he kept that.
I pulled the computer out from behind the glove compartment, got all the door switches, and the relays from behind the radio.
My PM box is about full, so if you don't post here, and get a box full message, just hang on and I will make some space.
Everything is "as is", and all I want is shipping. I have no dog in this hunt, and don't intend to charge anything.
Since most everything is probably widely available in junkyards locally, I doubt I will get many takers.
I just did not want something useful to go to the crusher if I could help it.
One good thing, I got the throttle body, and will be taking it apart soon. I have been trying to advise folks here how to fix theirs for several years now, its about time I actually see what one looks like..........
