garydan
I have what I believe to be a 4-bolt main 400ci motor since it has 3 freeze plugs on the side. The freeze plug on the drivers side closest to the front of the motor is leaking. Unfortunately its right behind the motor mount. Will I be able to replace the plug without removing the motor?
