I have a fresh 350 SBC for sale, ran good when removed. the only reason this engine was taken out is because the previous owner built a 400. it held excellent oil pressure didnt smoke at all, it has a holley intake, RV cam, a new water pump on it, and comes with distibuter, flywheel, starter. it does not come with power steering pump or brackets or alt. or pulleys. Im asking $500.
Im located in Sikeston MO. Im selling several to buy a truck I found.
also have a turbo 350 and NP203 transfer case, tranny was rebuilt less than a year ago. still has 6+ months left on warranty. converter was replaced as well and is included. $250
96 vortec heads, almost new. $325
ZZ4 GMPP roller cam, was installed but never ran the engine. $75
B&M torqmaster 2400 stall converter for turbo 350 removed from box but never installed or used. $85
350 SBC chevy no oil pressure smokes will remove this week. I believe it is an 87 or so with roller cam, roller tip rocker arms, holley intake. but does not have centerbolt heads. you can have everything attached to it for it $200
350 SBC shortblock, roller engine very clean, very few miles, the engine would not turn over very easy so I removed the heads and discovered rust in one cylinder. you can still see the crosshatch in the cylinders, 1996 model. $150 with aftermarket deep oil pan.
SBC comp cams cam, ran it for 2000 miles and took it out because I didnt have good brakes. .488'' intake .510 exhaust $50
weiand intake one carb stud hole is questionable. $50
edelbrock carb, ran very well, just removed it last week. I beleive it is a 1405. $75
marine power aluminum 4V vortec intake. $85
any questions just ask, I will get pics upon request. all parts located in Sikeston MO. I can accept Money order or cash upon pickup. I can also ship, I have a UPS freight account and get a discount.
