I have an issue with the 350 in my '77. Until yesterday, it had a holley 670 truck avenger carb on it that the PO installed on it when the motor was rebuilt and had troubles with it since day one. When I bought it, it would pop rapidly out the exhaust and lose power, but only under heavy load and in the upper RPM range. On a cold start, it would feel like it was flooding out during very light throttle, but if you revved it once, it would clear up.
It wasn't a very big deal and was plenty drivable, but I messed with it anyway
After adjusting the idle mixture, float level and accelerator pump, the problems were about 75% gone, but only for about a week. Then they started getting worse again and stayed that way for a couple days, then over the course of a day, the truck became very hard to accelerate. If I gave it too much throttle, it would pop/backfire VERY rapidly through the carb and make NO power.
Convinced there was something major wrong with the carb, I removed it and installed a used 670 Street Avenger that a buddy used to run on his Trans Am (after taking it apart, inspecting it, replacing some seals and fixing a float spring). This carb is doing basically the same thing. It idles a little rough, and pops rapidly through the carb when I rev it. I'm afraid to drive it to see what happens.
Fuel pressure is between 4 and 6 PSI, and vacuum is around 15-16 during idle. There is no black smoke from the exhaust. The plugs looked OK, maybe a little glazed, but I replaced them. Also, a lifter started ticking right before the drivability issues got really bad. What the heck is going on here? Please help!
After adjusting the idle mixture, float level and accelerator pump, the problems were about 75% gone, but only for about a week. Then they started getting worse again and stayed that way for a couple days, then over the course of a day, the truck became very hard to accelerate. If I gave it too much throttle, it would pop/backfire VERY rapidly through the carb and make NO power.Convinced there was something major wrong with the carb, I removed it and installed a used 670 Street Avenger that a buddy used to run on his Trans Am (after taking it apart, inspecting it, replacing some seals and fixing a float spring). This carb is doing basically the same thing. It idles a little rough, and pops rapidly through the carb when I rev it. I'm afraid to drive it to see what happens.
Must be that cheap overseas crap.
