A friend of mine has to repair a 92 CJ Jeep's clutch slave cylinder...Jeep has a lift kit,maybe 2-4" installed in it...when the slave cylinder went south,the owner bought a used one from a salvage yard (against my friends suggestions,but he is low on cash)..anyway,he's not a mechanic,when he went to pull the slave off it,he didn't know how to release the hydraulic hose from the slave cyl,which has a roll pin that must be inserted after putting the hose in --so he used cutting pliers to snip it off!!..
...and he cut it practically flush with the slave cyl too............................................................................................................................................................................................................The hydraulic line on the jeep evidently came with the lift kit,as a stock one is now too short to fit now,and it was damaged from rubbing against something and is about to pop,so he doesn't want to re-use it...calling around to 4x4 shops and parts stores has resulted in dissapointment,as they all claim they cant even supply a stock line,and it wont fit anyway,being too short..dealer wants almost 150 bucks becuase it come only attatched to the slave cyl!..and the 4x4 shops say the only way to get that "custom" extended line is to buy a lift kit! (has to be BS,I cant believe that!)...we've tried and failed to splice two halves of each hose together with push on hose barb fittings,the hose is some hard plastic stuff that wont let the barb fittings slide into it,and heating the fitting or hose just ended up ruining it..............................................................................................................................................................................................................I would think there must be some kind of extention for the stock line you can buy,or a longer custom line separately avialble from some source??...the owner took all the remains of the old lines to a hydraulic hose shop to see if they can make something that'll work,but I doubt they will be able to duplicate the end that goes in the slave cylinder--the clutch master side has a female nut fitting,so that might be possible to duplicate,but its probably some bizzare metric O ring fitting thread that wont be cheap.................................................................................................Anyone have any ideas??...
