andyblack
Registered Loser
I thought the bore was actually supposed to be 2.00.
Uh oh. Where would I look up that kind of information?
So the driver's side bearing is an old bearing the will fit on both spindles. Does the new bearing that doesnt fit the passenger side fit on the driver side?
Did you polish the spindle?
The spindle nut procedure is tighten inner spindle nut to 50# and spin hub/rotor to seat bearings, then back off approx 1/4 turn. But the 1/4 turn isn't exact since you will most likely need to adjust it to seat the washer over the nipple is you have stock spindle nuts.
After you tighten to 35 ft lbs, you are supposed to back it off again about 1/4 turn.
