gonefishin
when i was tearing down my 10b to install 8 lug outers i noticed i had some bad things going on
i had water in my hubs and now rust too did not make it to wheel bearings but i will repack when i install with 8 lug stuff along with new axle u joints
my inner bearing in my spindle not sure what you call it anyway it went out and chewed up my stub shaft a little on my drivers side and passenger isn't much better
my question is should i just clean it up best i can or find a stock stub to replace it with or should i put some chromo stubs in it with my stock inners will they work together? i have the later 30 spline inners they are supposed to be a little stronger but i don't know how much
any thoughts other than a d60
