The 56's wont give you any more "useable" flex or ride quality over the 52's. The 52's will flex farther than most driveshafts, brake lines, and shocks will handle anyway. The 56's will probably result in a bit more spring wrap up front.
The upside to the 56's over the 52's in the front is you dont have to reloacate the shackle hangar. Just move the front mounts. This varies of course and some here have ended up having to add longer shackles or notch the body mount for shackle clearance.
Either setup will net similar results and vary based on the condition of the springs.
Remember for either of these swaps. Crossover steering, Long shocks and taller towers are necessary, and a long slip drive shaft will all be required to get the benefits from. Its a cheap easy way to get a lot of flex up front.
The downside is the streetablitiy of the 52's and 56's is less than optimal. Lot of body roll during cornering.
