front 8-lug ten bolt or d44 in nov california
I have what you need. Shipping might be a deal breaker. If you don't find it closer let me know.
It would be alot easier to just swap the outers to 8 lug and keep your current axle. I'm assuming your current axle has the correct gears to match your rear.
I got a 8 lug 10 bolt out of my 87 burb $150
And my wife will be in Sac this weekend
Let me know
Todd
im goin 4.56 and im currentley runnin 3.73
Gotcha. I'd be careful running 4.56 in a D44 or 10 bolt unless you are easy on the skinny pedal and aren't running anything larger than a 35" tire. The pinion gear becomes too small with those axles once you start getting into 4.56 gearing.
yea im only runnin 35's right now
