How do you figure out how much lift you need when you change to your coil over kits? I have a buggy that I want to convert to coil overs front and rear but I have no clue how much lift it has now. Thanks
There are really two ways to approach that. We can take some measurements off of your truck and figure up about how much lift it has now. Or, you can set the axle and frame in relation to each other how you want them and then install everything at that height.
