Ok thanks.....I guess I'll live with it! Just wanted to be sure I didn't screw something up when I put it all together.1/4" is factory tolerance...
Regardless of year, all squares were developed in the very early 70's....
1991 K5 is just a 73 with updates...
We've been trained to carry 700 dollar computers in our pockets, get our food just the way we want it, (because it is my job) have concrete poured at a perfect consistency and as flat and true as a piece of glass....
1/4" is actually pretty good.
I have about 50 miles on it now, so I'm torquing the u-bolts. What else should I tighten? Thinking sway bar, should I do the eye bolts too? And maybe let everything hang instead of having the axles sit on the jack stands.Make sure you re-tighten everything. I have completely removed axles from my truck, and then torqued to specs everything back together. I then pulled forward and backward in my driveway only about 10-feet. When I went to re-tighten everything, I was surprised at how loose everything got after only 10-feet of movement. I then re-tightened everything again after one trip around the block, 10-miles, and then 100-miles. After the 100-mile mark everything should be tight for a long time.
Got it, makes sense. Thanks.You want the suspension at ride height when tightening everything, in other words jack stands under axles. This way you don't bind up the bushings by tightening them at one end of their travel and then forcing them to sit static at the other end of the travel, you want them in a neutral spot where they spend most of their time(ride height).
