4bynut
I'm having problems with my 1996 GMC sonoma. The front axle won't engage. I've checked the cable and vacuum pod and their OK. I've also replaced the switch on top of the t-case and still no luck. I'm not getting vacuum to engage the actuater. There is a switch by the battery which connects to the vacuum line. I'm not sure if that could be the problem or not. any help is appreciated. Thanks Jason
