I am looking for the Driver and Passenger side brake lines going from the PV to the frame. Due to years of corrasion I had to remove from the Truck with vise grips and destroyed the Hex on the nut going into the flex brake line from the frame to the caliper.
I am not sure if the Blazers had the same type of brake lines, but asking here since I know many of you dabble in parts of Blazers, Suburban's, and Trucks.
I need both the Driver Side and the Passenger side ... I know LMC sells the 4 piece set but the mains from Master Cylinder to the PV are good, I would rather not have to purchase the full set if I can locate Good pieces where the hex on the fittings are in good shape.
Pictures are of both sides .. the passenger side in laid on the frame where it belongs
Thanks,
Rob
Thanks,
Rob
