front brake question
mollyman
west virginia
i have a 81 1500 sub that i bought a set of extended brake lines for but now i am putting in a d60 will the kit still work with the fittings on the d60 brakes ?? also i know this has been talked about before but i just need a simple answer -- since i will now have a dana 60 front and a 14blt rear with discs what booster / master cylinder should i use, also if it matters i plan on getting rid of the factory prop valve and installing an adjustable one to control the rear. i didn't know if maybe something like a late model chevy 3/4 or 1ton with rear discs might work or what?? thanks for any help !!!!!!!!
Brake lines will work, i just finished putting a D60 in the front in place of my old 3/4T 10B, steel braided lines that were on the 10B works fine with the 60. MC is another story, some searching these forums will find one if you are using vacuum booster (i think its a 93 C3500 4 wheel discs), i just put the original type on mine but i run hydroboost.
I installed Summit Racing adjustable proportioning valve to my rear brakeline and it helped alot. No more rear wheel lockup.
