Front Brakeline Reroute
kicker30
Walnut Cove
For those of you that have moved your front brakelines to a center drop and then run across the axle, how did you do it? Did you use a single line with a split at the axle like the rear or still run two lines but have them drop in the center instead of at the sides? If you ran one line did you use the same proportioning valve and just block off one port or switch it? Also did you just run it down the engine crossmember then drop it to the axle? Thanks, I am considering doing this since I have my Blazer completely apart and wasn't sure how to go about it.
I havent done it yet but when I do I'll run two soft lines. You need to keep soft lines on the end for steering obviously then run hardline to the center of the axle, then run two soft lines. I dont think you can T them seeing as how the MC has two front outs. I would think that would goof the cylinder up.
