Front Corp. 10 bolt with Spicer axles? Am I nuts?
johnnieg
CSU, Ft. Collins, CO
I was crawling under my truck and happen to look at the steering U-joints which were tunred just right to see "SPICER" on the axle side of both joints. Did 10 bolts use spicer axles or is this an aftermarket upgrade or replacement piece? If you need pics I can try later.
Re: Front Corp. 10 bolt with Spicer axles?
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif *ben stein voice* "anybody? anybody?"
I think the dana 44 and the 10 bolt use the same u-joints. So you probably have spicer u-joints in the front axles shafts.
[ QUOTE ]
[/ QUOTE ]
My rear shaft slip yoke end has spicer stamped on it?????
[ QUOTE ]
The original axle shaft u joints were Spicer, at least all I have replaced.
[/ QUOTE ]
Yep. As stated above, same size u joint.
