front diff looks wider than rear
blazen88
Registered Member
rancho santa margarita
is this normal to have the front diff wider than rear. i havent measured it but it sure looks wider, right now i have the ten bolt front and rear. still looking for six lug 14 bolts for my blazer. do they come in different widths. seems like i have seen a few running down the road with the same look i have, but most look to be the same width. but nothing seems to be alterd on mine.will i be able to use my 15 inch rims on the 14 bolt six lug (if i ever find some) i read something about bigger brakes. and about the width shouldnt they be the same on 3/4 and 1/2 ton stuff spring perch and overall width
front is 3" wider, six lug 14 bolt is a semi floater and it is a rear axle. I believe it is wider then the 10 bolt rear and is a definite upgrade from your 10bolt. If you find the correct truck it is a bolt in swap.
the track width sp? thats normal my d44 and 14blt are the same way im 8 lug. the ones that look the same may have spacers dunno jst my 2 cents. im sure if im wrong itll be corrected
