I'd say it depends on your application..I'd think rock climbing and mud bogging would be excellent applications for a front locker.
I had contemplated it, but decided not to,with the whole "steering in slop" issue.
Almost lost my truck hunting, and had I a locked front diff, I very well may have. Off camber slope angling towards a canyon, snow, and gov-lock rear...I was lucky the tires bit in before the rear reached the edge. Ended up shoveling snow down to gravel before attempting to move the truck any further. The front diff NOT being locked is what I attribute staying on the road to, not down the hill 1000 feet or so.
As soon as the ass end hit the off camber patch the front end had just cleared, the rear end started to swing out, while the front end stayed planted. All forward movement stopped, but as the rear slid, the front ended up facing more the uphill slope than forward.
As I've seen it said before, the one wheel not spinning acts as an anchor of sorts. With the semi wet, maybe 6" of snow I was in, the tires spinning were getting NO grip. There was absolutely no tread pattern where my tires had gone before, except the side lugs, which were likely what got me that far along in the first place. I can't blame the tires (BFG AT KO's) as no matter what tire I would have had, I don't believe the situation would have been different. Flooring it with more aggressive tires may have dug down, but with 6" between me and the bottom, I didn't really want to test that theory out with the AT's : )
Dorian
My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>
www.dorianyeager.com/index2.html</a>
Why insist on counting when the ring gear has the tooth counts stamped in?<P ID="edit"><FONT class="small">
Edited by dyeager535 on 11/16/01 12:46 PM.</FONT></P>
