Front drive shaft bolts
blank
Registered Member
Texas
OMG!! I cannot find anybody who knows what front drive shaft bolts I need for my 87 k5. I need the bolts to put it back in. The flange bolts and nuts at the back of the drive shaft and then the u-joint bolts for the front of the driveshaft.
So I go to old faithful you guys. Has anyone else had this problem?
Never had that problem. I do have a set of flange bolts though if you need them bad enough. The flange should have threads and no nuts are needed on the back side. NAPA should be able to hook you up with the axle end u bolts.
Thanks Wayne napa does have the U bolts but they do not know what flange bolts I need. I will find some you might need yours. Thanks for the offer.
I actually need longer ones for my new driveshaft that I am building. I think they are fine trhead 7/16 but will have to double check.
