I recently swapped out my Np203 and 10 bolt for an NP205 and a D60. Unfortunately the drive shaft angle appears to be to much for the CV and it binds at ride height
I'm running 52's netting 6sh or so of lift with 454/350/NP205 combo, front axle is moved a couple inches forward.
Here is the drive shaft in question
As you can see I have about 26.5 degrees of angle in the CV. The axles castor is set at about 7-8 degrees and rides pretty nice as is. I'm also concerned that there is not enough slip in this shaft, what's an ideal amount of slip for the front?
