Front Drive Shaft
prburson
Registered Member
Phoenix
So this is what I have I just put together a np205 and finished off the doubler. The np205 has the front 32 spline output. What I need now is a to get my front drive shaft work. I figured I could get a 32spline mounting flange from high angle drivelines but I would need a flange type cv joint for the shaft then just get it lengthened.
Does anyone have any ideas on where i can get a CV joint probably?:confused:
Or should I just get a new drive shaft built all together? :confused:
Thanks for the imput:bow::confused:
Jess at HAD had a flange that was 32 spline and fit the GM CV if you just want to get your stock drive shaft lengthened. Cheaper.
The easier, stonger route would be to get a new drive shaft built and one of Jess's drive flanges.
PaulC
