1988 K-5 Blazer, front drive shaft, differential side, Dust Cap Kit Part number please?
Thank you,
Ed
Thank you,
Ed
A seal there helps keep the grease in and the mud and dirt out. Water, mud sand and whatever will decrease the life of the slip joint over time. At least I from what I have seen.I guess I always ran nekkid. I dont think any of my squares ever had a dust cap on the front driveshaft. Never had any issues.
Those "caps" are worthless IMO.
With them on the front shafts wear out, even with regular lubing. They still allow dust in, and once the dust gets mixed into the grease, it abrades the splines. They could never work well since they are not working on a smooth surface. If you look at some of the shock boots available, those can be used. I'm using one on the rear shaft as well. Just zip tie them in place, trim to length before, if you like. Front may be a 100% solution, the rear is likely to be too big in diameter, but the boots are fairly rigid, so you can zip tie to the narrow end and let the "open" end .
Then the grease that you are using is horrible. Working on equipment and mixer trucks, I have seen the difference in grease quality.
I rarely see that blue coating intact, most peel off.The driveshafts I've had apart that have that blue plastic coating on the slip yoke splines are always tight and in good shape--ones without it are usually loose & sloppy,and looked like they never got greased after leaving the factory..
I would lose no sleep over a lack of that grease seal in the sliding yoke--as long as you pump in fresh grease once in a while,any dirt will get pushed out..I've had several drive shafts that didn't even have that fine thread nut with the seal on the slip yoke and didn't have any issues with the splines wearing out..
