front driveline bolts
bigbadchev84
Hermiston, Oregon
anyone know the napa part number for the front driveline bolts up at the t-case? I have a 72 blazer with a 465/205 setup with a yoke one the front output. Already got the front axle u-bolts. Need to get this thing 4x4 for the crappy weather ahead
Ok here is my driveline, It just takes a fine threaded bolt of some sort that goes through the yoke and threads into the cv end of the driveline. I NEED THE NAPA PART# they cant seem to find what i need
ohhhhhhhhhhhhhhhhhhhhhhhh u bolt clamps? i called up and explained everything and they typed it into their little computer, thats what i did at least.
there not u-bolts though, They are just a straight bolt that screws into the cap that is on the u-joint in the pics. My old 205 had them, just have no access to it anymore, They are just bolts, no strap or anything
I got you now, the bolts go thru the caps on the CV end and thread into the tcase yoke.
IIRC you can just use a grade 8, 3/8" or 7/16" fine thread bolt. You just have to figure out the thread. Do you have a tranny shop over there you can swing by at? They should be able to have some or get you some.
