I been running front driveshaft angle through my mind the last couple of days and have some basic questions about reducing them.
If you press off the in knuckles and then rotate the house so the pinion is point at the tcase and the set the knuckles back on at the stock degree, which I think is something like 5 or 6, do you stand a chance at drying out the pinion bearings?
I know they make shims, but I've always been told that changing the caster will lead to poor drivability.
I know in smaller lifts say 6 and below it dosen't seem to be much concern about driveshaft angles.
So, what's the stroy from you side of the hall?
