Doing some calculations for the "Might As Well" build.
With the driveline in place, the front driveshaft is a total of 42" long. YES, that's right....it's about 6" longer than the rear driveshaft!!!
I'm not running much lift (maybe 7" total) and by my calculations, the current u-joint angle at the D60 yoke is 22.39 degrees. That does not account for the fact that the pinion is turned up slightly toward the xfercase (10 degrees)...so my effective operating angle should subract that out.... for a total operating u-joint angle of 12.39 degrees.
Sounds good....except that I'll end up with a miserably long front driveshaft that is going to be a rock-magnet because it's sticking out across almost half of the underside of the truck!!
My thought is to build a 2-piece front driveshaft with a carrier bearing at the pivot. This will allow me to run a straight section of driveline parallel to the frame (up out of harms way) and then drop a much shorter front driveshaft more directly to the yoke of the D60. I've been playing around with a few numbers, and effective u-joint angles.
10" straight section / 32.9" driveshaft = 19.03 degrees @ u-joint
12" straight section / 31.2" driveshaft = 20.81 degrees @ u-joint
16" straight section / 27.8" driveshaft = 25.02 degrees @ u-joint
Remember, those angles already account for the 10 degrees of angle that are in the D60 pinion, which make the angles look better than if the yoke was 100% parallel to the ground.
I haven't run the calcs yet for when the suspension cycles (up or down) either way is going to make those operating angles worse... the question is by how much. I'll figure that out later tonight or tomorrow.
Ultimately, what I want to know now is:
What is the maximum safe operating angle for a front u-joint? I am assuming that the D60 is a 1350 style yoke, since I haven't swapped out whatever it came with stock. I realize that unlike a rear u-joint, it will not see 100% duty cycle, but I also don't want to be spitting out joints left-and-right on the trails because I am running too steep of a driveline angle.
Any input???
Any input???
This whole thread is an interesting idea, and I'd like to see what comes of it. I think you could put a CV at the xfer case and single cardans at the carrier and pinion. That should allow you to angle the stationary section without any problems.
The CV is necessary to balance the angles IF the pinion is tilted up to a different angle than xfer case output AND first section of d-shaft (from xfer case) is tilted down (rather than run parallel to output shaft), because overall angle between xfer case and pinion wouldn't match. On the other hand, it's a front shaft and he may not care about a little vibration.
