Did GM ever use a driveshaft boot on the front? If they didn't, is there a solution known to work with a stock 1/2 ton front shaft?
I'm pretty good with maintenance, but for a rig that sees less than 3000 miles a year, taking the shaft off and getting a face full of powdered rust seems ridiculous. I know it's pretty common for the front shafts to be in terrible condition (at least from other ones I've seen, the lube doesn't stay put very long, and people don't seem to worry about lubing them regularly), and I have to think that much of the problem comes from the "seal" used, if you can call it that.
A driveshaft boot would help, but it doesn't seem like there are many options out there in boot sizes. I suspect shock boots are generally too large in diameter?
