I have a 1980 k5. Doing a 5.3 wih 4L60E. Keeping the np205. The problem is the front driveshaft hits the tranny oil pan. Any suggestions on what I can do to clear oil pan?
Maybe if you lower the T-case by putting some spacers between the frame and T-case crossmember you'll clear the tranny. I just put the factory spacers in between the frame and crossmember like in the first pic, but then found out that could break the mounting bolts off or even crack the frame so I fabbed some solid 1" plate spacers like streetgliderx did in the pic below.
