if its stock,you have to measure the length from the ujoint yolk on the axle and the transfer case and go to the junkyard and find one the right length.most will be the same if there is no lift and also have a 203.check the ujoint yolks and make sure they are good and the correct size and you should be good.get good measurements and check the slip yolk for good splines and no play also.
i almost forgot,congrats on the awesome ride.the full convertable tops are getting harder to find these days.Pics??
If you have the old style CV yoke on the driveshaft, that has 4 threaded holes and used bolts to hold the u-joint in,I have found that a 90's 4x4 dodge dakota front shaft is a bolt in swap for some older GM 4x4s,they used the same setup & length...
