front end alignment 89 jimmy
89 jimmy
Bay Area Ca.
My front tires are wearing alot more on the outside edge. If u look head on at front of truck u can see the bottom of front tires are in and the top of tires are more out(i forget what u call this). Anyway, could this be worn ball joints, or do I need shims? Took it some alignment shop few years ago but they never really fixed it and charged me alot of money. If it is ball joints are they easy to change with normal tools?:confused:
Could be either or both. Are you sure you have ball joints?(some axles have kingpins) You should first rule out the ball joints as the problem.
Raise the front of the truck and check if there is any "play" by grasping the tire @ 12 & 6 and try rocking it. This is the "quick" method of checking. There is another method that requires a strain gauge and turning the wheel, but I've never done it so I cannot advise here. If you have even 1 bad ball joint I and "many others" would recommend changing them all along with any other parts found unserviceable along the way.
Can you do it yourself______Short answer is yes, is it as easy as changing you oil____Hell no. You should invest in a ball joint service kit (not really expensive) and dedicate a whole weekend "just to be safe" There are many threads here about replacing ball joints...."search function"
As to the alignment, #1 find a shop with an "old timer" doing the alignments (he is usually more versed in SFA vehicles) #2 make sure they have the alignment shims "in stock". My experience finding a shop that has the shims is, in a word___exhausting. I have found "NO" shops other than a dealership that has the shims. #3 Determine from them if they go "within spec" or "to spec" There is a huge difference (especially with tires that are within a couple sizes larger than stock.) If you have 35" or larger tires look for a place that is experienced with 4x4 alignments, as there are different angles that need to be achieved for best performance.
Here are the spec's I have for the blazer alignment
____________________________________L-Caster_______R-Caster________Camber________Total Toe
Blazer, Jimmy Full Size 77-91_________8.00° ± 1.00°____8.00° ± 1.00°____1.50° ± 0.75°____0.12" ± 0.05"
Hope this helps, and again "search"----- it is your friend.
Check your balljoints. Just google "How to check balljoints" there should be plenty of info. Basically you just pry on them to see if theres play.
If there is replace them. You can rent the press tool from any chain auto parts store.
If you replace the balljoints and its still off then they make shims for the spindles to correct it. Gotta be careful your housing isnt bent though. USUALLY a solid axle you dont have to touch camber (which is what your describing btw).
I really wouldnt bother going to an alignment shop. The toe can be done with a tape measure, caster with a $5 angle finder, and camber by eye
will do soon as i can my laptop just took a s**t on me!!! till i can load pics its just as i described you can see that the bottom of tires are in more than the top causing alot more wear on outside front tire.
It doesn't mean the bottom is in more than the top! It sounds more like a Toe-in situation......a picture would help. Until then it makes NO sense that your solid axle is having that issue!!:dunno:
When the tire is turned, it leans and rides primarily on the outside/inside of the tire (depending on which tire we're talking abou). This is because of caster, which is a good part of alignment while in spec.
If you have to do a 180 every day to park your truck and don't do it slowly, you'll quickly wear out the outside of the driver's side tire. No problems with alignment, nothing wrong with the truck, just slow down and the tires will be fine.
If you haven't checked ball joints, do that ASAP, though typically they cause wear on the inside of the tire.
