front end conversion
chivo
tucson
hello im new to the site and i love it already.
i have an 87 chevy 1ton silvarado single rear tire 4x4 454 pretty much all stock. would like a good 4inch lift on a budget been looking at the rear flip and the b52 front. my question is will the 56's work with these mounts and will it be a true 4inch
first off budget and 52 or 56 " front spring b52 kit is not in the same park.
you will need lots of stuff other than just springs. steering will need to be crossover/shackles longer and repositioned rear hangers possible/long travle shockes/and ford upper shock mounts. just to name a few.
there is a few good write ups on here for this.
and if you want a budget build and good ride i would go 4" flip rear and tuff country 4" hd as you have the bigblock . good ride and good flex.
ord has deals on the master kit everything you need to bolt on and go. www.offroaddesign.com call them up and ask .
I have a ord kit and its great. Still pull/haul but it has good flex.
