gotblazers
Hey guys so im getting grinding on my dana 44 under certain conditions on the passenger side. ill start off by telling you what im running
76 k5 blazer
4'' suspension lift
stock dana 44 front
171k miles
used to be a support truck for a score racing team so its safe to say its been run hard
tell me if anymore info is required or if your just curious about it
It use to only happen when i turned onto this tiled concrete (small ruts all over it similiar to bathroom tiles) and even here it was rare. I figured it was my hubs so i replaced them with warn locking hubs (very sexy
) which work great now and stopped the grinding on the road but i just went off road and im getting the grinding coming out of the right tire off and on still. The problem will stop if i slow down or if i turn left or right a little or a combination of the 2.
The problem will occur under these conditions
.If my front right wheel has to flex up or down too much at these speeds ONLY
.speeds of 15-45mph
The problem never occurs under these conditions
.slow speeds 1-5mph even if i have the axle flexing hard
.high speeds 50mph and up (freeways)
76 k5 blazer
4'' suspension lift
stock dana 44 front
171k miles
) which work great now and stopped the grinding on the road but i just went off road and im getting the grinding coming out of the right tire off and on still. The problem will stop if i slow down or if i turn left or right a little or a combination of the 2.The problem will occur under these conditions
.speeds of 15-45mph
I still need to take mine apart. It never happends on road since i changed out my hubs and tightened my wheel bearings so im just going to check it out some time before i go to blazerfest. I hate deconstructing my DD though
. I torqued it up to about 12ft lbs then spun the wheel a few times to seat it then i torqued it up to 20 and spun it a few times to seat and backed it off a 1/4 turn. I didnt replace anything but the hubs so i didnt see any need to torque past 20 to get them to seat properly. i dont recall any washers although im sure there was but it was over a month ago so i just dont remember likely. I dont think i touched the axle nuts for just swapping manual hubs as thats all i did. Its a 171k mile vehicle which was used as a score racing support truck for part of its life it seems likely that the bearing is just worn but the question is which one
. Im positive i got the inner nut up to 50 lbs i was just confused what you were talking about before
. I'll try and find sometime but im a bit of a procastinator lol. I oughta make a build thread for my 76 and 73 blazers so im not posting new topics every day.
