Ok, so my burb doesn't see much 4x4 time. That's no secret.
Last few times i've thrown it in 4hi in the snow though, the front drivers side pops intermittently under load.
Light load, no noise. Bury the throttle, and get an intermittent popping noise ever 1, 2, 3 seconds, etc.
Front ujoints were new when i put the axle in last year. Front drive shaft joints are good.
Have taken the front end / outer assembly apart multiple times since i first heard the noise, so doubt its a mis-assembly issue.
Any ideas?
Any ideas?
You may have a bad hub. Try switching them from driver to pass side and see if the other side starts popping.
