Front end width measurements
mtnman210
Northridge, Ca
I'm sure this has been done before but I couldn't find it....
I'm looking for a "real-world" measurement on outside to outside tire measurements. I'm looking for 60 fronts and also 60 rear measurements.
The info I'll need is:
is it front or rear
outside tire to outside tire measurment with full truck wieght as it sits
rim diameter,width,backspacing
tire size and what psi is in the tires
I'd like to see a good amount of different tire sizes I hope.
yeah I've seen the 60 bible. But it doesn't have the measurements I'm looking for. It only shows the axle width. I'm looking for the full width of axle with tires and rims.
I'm just doing a little comparison research for some thoughts on a new rig.
This could be a good thread with those kinds of measurements. Always nice to have easy access to that kind of info for all kinds of builds. Maybe we could also include sidewall to sidewall width so we would have the 'overall maximum width' too? I'll take some measurements tomorrow.
60 measurements
My 82' Blazer had a 60 front w/35x12.50x16.5 on American racing outlaw 2 16.5x9 3/4 wheels and the total width was 83 1/2"
'85 SRW front D60
87.5"
Mickey Thompson Claws 38x15.5x18 ~35psi
11" rims with 4.5" BS
1985 K30, 16.5x10 rim, 4.5 bs, 15-39.5-16.5 TSL Swampers (30psi):
Frt D60 - 86.75"
Rear 14ff - 83.5"
1985 K30 Crewcab with factory box, Q78-16 TSL, stock rims (6.5" wide?) (30psi):
Frt D60 80.25"
Rear 14ff 78.25"
1989 K5 with a Dana 60 front, 16.5x12 steel wheels with 4" back spacing, 44x18.5x16.5 Ground Hawgs, 20psi:
92" outside to outside.
Forgot you mentioned wanting back width. I'll get it for you in a few.
86 K30, 16.5x9.75 American eagle alloy wheels 3.5 or 4" backspace 38x16 TSL's front end measures 88.5" IIRC. - when stock with factory steelies and 235/85 tires it was about 81" as it fit between the fenders on an 83" wide trailer with about an inch on either side.
Front: Dana 60, 15x14" Procomp Rockcrawler wheels w/4.5" backspace, 18.5/44x15 TSL's= 95.5"
Rear: 14 bolt, 1.5" spacer/adapter, 15x14 Procomp Rockcrawler wheels w/4.5" backspace,18.5/44x15 TSL's = 96"
all tires ~10-12 psi
