Here is my cut out front floor support that I'm patch welding. I'm debating if I should just replace the entire thing. I'm hesitant to go into the joint and body mount area.
Would this be ok to weld if I clean it up some? I was getting alot of blow outs in the section I patched in the pic below because the metal was so thin.
