JST12
I am having troubles installing new Warn Premium front locking hubs and was hoping someone else has seen this and might have a solution. One hub went together just fine, but on the other side the internal hub assy hits the theaded spindle where the wheel bearing lock nuts go. The hub is not hitting the lock nuts, just the threaded spindle. I measured and it is sticking out 1/8 inch more than the working side. Does anyone know why this would be, or how to correct the difference in spindle position inside the hub? This is a 79 3/4 ton axle (10 bolt). Any ideas? Thanks, JT
