StevoandaRedK5
Ok, after getting my truck back on the road and driving it today, i had a grinding noise coming from the drivers side front hub on the Dana44. I replaced the hub a few weeks back since the old one was out of round and allowing the bearings to chatter. I have been having trouble with the brakes as well, so i wrote off the noise to a dragging caliper. Not so...I took the wheel and tire off this evening to discover this:
So looks like either the hub was sitting too far back on the spindle, or had way too much play which let it wobble around, allowing the rim to cut this groove in the joint... Here's what the spindle looks like after cleaning it up:
So I pulled it all apart, replaced the inner seal that was all torn up, and have been trying to get rid of the play to no avail, it's still there no matter how tight the locking nut is...Is the spindle the problem? The replacement hub i swapped on is off of a 10 bolt, i was under the impression they are identical. thanks in advance...
I just wanted to be driving it, cuz the furd taurus is not cutting it
