I have original '86 K5 Blazer leaf springs front and back on my truck. After my 5.3 Vortec install, I now have very little clearance between my front diff and the oil pan. I'm affraid I'm gonna bust it open when I start flexing and moving the suspension around while offroading. I do not want to install a lift kit (I like my factory height or close to it). I've already replaced the oil pan with the shortest one I can find. So, this leaves me with few options. My best guess is that I need to maybe install a 1/2 inch spacer between the axle and leaf springs or maybe add a leaf spring. Replacing the entire leaf springs is really costly, so maybe just adding a single to each side would be more affordable. Thoughts? I really only need an additional 1/2 to 1 inch of clearance between my axle and oil pan.
Way back in the day I used to have some air-up-yourself shocks that you could air up with an air compressor and the shock would raise the height of the vehicle. Kinda thinking about doing that too. Any ideas or suggestions?
It's either at riding height or it feels like it's bottoming out.
They are made in Detroit of all places
