joshkbomb
I'm going to be replacing the bushings in the front leaf springs (truck has broken bushings that cause it to wander around the road) on my '87 Blazer with a stock suspension and I have a few questions before I jump in:
1. I'm worried about the angle that the frame will sit on the jackstands (front of truck pointed up) to get the front of the truck high enough to remove both springs. Is this a problem or should I not worry about it? I assume also that I should position the jackstands right behind the shackles?
2. How do I make sure everything lines up when I go to install the springs? I have to remove both of them to take them to a spring shop, so I can't do one at a time. Is the truck probably going to need an alignment after this?
3. Are urethane bushings (greasable maybe?) worth the extra cost given my truck doesn't get much wheeling in anymore ($45-50 vs $95)?
I'm also in the process of deciding whether or not it's worth doing all this myself. The spring shop said they would do everything for $360 which, given how motivated I am right now, sounds pretty tempting. Doing it myself would cost $170-200 in parts/tools. What would you do?
