front lockers
ace 88
Newbie
michigan
I just purchested a set of manuial lockers :Dfor the front of my 88 blazer and cant get the stock ones out.:confused: can any one help. cant find my book.:mad:
Are you having trouble getting the giant internal snap rings out or are you past that point? If you have gotten the rings out just screw 2 of the allen head bolts back in, one across from the other, and it should wiggle out.
If you have the cap off the hub. Look at the outer diamater of the automatic hub.
You will see a metal plate on the outer edge. Pull off that plate. You will see 2 pegs in the space. squeeze them together. That will compress the lock ring and you can pull the hub.
