Front lower shock mounts?
edgewoody
Newbie
edgewood ,new mexico
Hey, anybody have a suggestion on where to get a lower shock mount
for the stock dual shock set up,close to stock,mine get all bent and need to replace it.:bow: thanks for any help
the Edgewoodrow
1987 K5
What do you mean?
Front mounts (dual or quad) are all the same, the (poor) design of the quad shock setup just used a bolt that extended out past the mount so that the second shock would ride on the exposed bolt portion.
I was asking if anyone uses just the front shock on the quad mount and if they changed how it mounts on the bottom, instead of on the exposed bolt end.
