fubar_k5
I installed my dana 60 in the blazer and while I was at it I switched my springs around so it would lengthen my wheel base now my pinion is about level with the ground maybe pointing down a little bit. I got 7 inch shackles on it right now was thinking about goin to a shorter shackle see if that might help.
But I was wondering what your guys pinion angle was set at with your 56" springs reversed or how much you had to shim it up. I can get pictures tommarrow. thanks for any input
